- Mar 15, 2011
[url=https://flic.kr/p/xxDkyY][...r.com/5718/20705156156_ae2753908a_b.jpg[/img]
[url=https://flic.kr/p/wNQora][...kr.com/264/20220702699_47dabea4f1_k.jpg[/img]
I have a question for you guys that have done your own lanyards for your Sebenza 21's. How the hell do you get 550 paracord through the little hole on the gizmo that mounts to the back of the knife? I've tried everything I can think of to no avail.
I cut about an inch of the strings inside the paracord and then I could run it through the lanyard pin without any problems.. Works every time... [emoji16]
I've tried that but I couldn't get it. I melted the end of the sheath and tried to form a point and it still wouldn't go. Any other tips?
hmmmm.. try to cut the end of the paracord that's going into the pin at a 45 degree angle so that it forms into a point and lightly flame it just to remove the fringes... Once you are able to insert that pointy part of the paracord, try using pliers to pull it out on the other end as it is a tight fit...![]()
