- Dec 28, 2012
I use 425 Paracord, it's closer to the diameter of the material CRK uses.
Thanks man, I'll have to give that a try as well.
hmmmm.. try to cut the end of the paracord that's going into the pin at a 45 degree angle so that it forms into a point and lightly flame it just to remove the fringes... Once you are able to insert that pointy part of the paracord, try using pliers to pull it out on the other end as it is a tight fit...![]()
If you don't use a lanyard what do you do with the lanyard pin? I put a small bit of type 1A para cord in it just to help it stay put in my zaan.
Double yep... oh, and I am a bead freak too...
@ Judge Luco: you don't need that lanyard pin at all.
@dubya3: That's an Umfaan.
20150427_220352 by brw713, on Flickr
IMG_1852 by brw713, on Flickr
20150627_001305 by brw713, on Flickr
20150725_210906 by brw713, on Flickr
20151116_223526 by brw713, on FlickrI never used the lanyard on any of my other Sebenzas. I never liked lanyards, and they always seemed to get in the way.
I could see where in a small seb, it could be beneficial though.
With that being said.....I have decided to try out the lanyard on my new large Insingo. The knife came on Monday and I left the lanyard on.
So far I like how it makes removing the knife from the pocket a little easier, but it still feels as though it's in my way when just clipped to my pocket.
The verdict is still up in the air for me.
What are your impressions after a couple of weeks?
I've never used the lanyards. I've either untied them on arrival, or performed the first disassembly right away and removed it then. That being said, I got the urge to give it a try on my Large 21 Basketweave, so I picked up one in burgundy with the blue spacer. The change is throwing me off so far, but I'll give it a bit to see if I adjust positively.
There are some great looking lanyards here!
