Aren't all fiberglass axe handles covered in polypropylene?I think the fiberglass handles do absorb overstrikes better than wood - provided that the fiberglass is overcoated with plastic. I've had fiberglass slivers from damaged hammer handles and I simply wont own a fiberglass handled hammer.
But fiberglass is OK for an axe handle. I still prefer wood for almost every use of the axe. However, a fiberglass handled axe is perfect for supporting an underbucking tool with a crosscut saw. The added flexibility of the fiberglass handle allows you to set the axe higher with a horizontal blow and then bend the handle down to support the crosscut saw. A wood handled axe needs to be set lower with an upswing blow. It's a more awkward swing and there's less spring to the axe.
The other trick to using an underbuck is to grind the edge bevel of your axe concave! Every axe book will tell you that an axe should have a convex grind. And for most work it should because the convex grind releases better - it doesn't stick. But when using an axe to support an underbuck you want it to stick. Hence the concave grind.
.___. Did people have any idea that flesh is basically a magnet for the stuff? I would've stuck with wood for the time being.Many hammer handles weren't. Early axe and pickaxe handles weren't. Seems like a no brainer now but the lesson was learned the hard way. Fiberglass handled tools used to come like this.
It seems like a wooden sledgehammer handle would break quicker than fiberglass though. I would imagine the strong vibrations that go through the fibers would splinter it quickly. I honestly can't decide between wood or fiberglass; I've seen guys with fiberglass axe handles that have lasted for a long time even with lots of use, but on the other hand I've also seen the same with wooden ones.My 2 cents. Fiberglass handles on sledgehammers are horrible, no shock reduction in my opinion. I would think it would be the same for an axe. I worked with a guy who used an old fiberglass handled hammer and he was always trying to get the splinters out of his hand. I have seen more broken fiberglass handles on shovels than I have ever seen on wooden handled ones. The fiberglass shovel and rake handles have a grip on the end to cover the hollow handle and that always seem to fall or wear off.
