Sorry if this is a stupid question but does anyone bring a bottle of oil to re-oil their blade during their outdoor activities? How often should I re-oil my knife? How often should I re-oil my knife if I use them regularly in wet areas?
Never. Provided I do not take the knife apart for another reason, I can get about 6 months to a year between reapplication of lubrication on an EDC.
More important than the frequency is the actual product being used. Some lubricants outright suck...they fail in reducing friction and they fail in preventing rust. If one of these products are used, chances are someone will have to reapply more frequently, will likely still be left with more long term wear on components, and will likely have to worry about corrosion.
Don't worry about it, the knife is not going to rust in just a few hours. Just take a dry bandana and wipe it down that night, and it'll be fine. A wipe down in the boring and again at night is just good maintenance.
Don't worry about it. The oil will come off but that's fine. I only oil mine when I can leave them at home on top of a paper towel. I don't want oil soaking into my pockets.
What kind of steel are you using?
Hi, I'm actually worried about the oil coming off. I will be going for a camp which lasts for several days. Should I buy a Fallkniven knife for multi-day outings?
Hi, how well does vegetable oil works? I handle food often and will be avoiding any inedible lubricants.
Vegetable oil is not advised. Like olive oil, it can go rancid and it will smell terrible, be a nightmare to get off, and isn't food safe once rancid if left on the knife. Like mineral oil, it may actually expedite corrosion over using nothing at all in some instances (in some cases, mineral oil makes rust worst in the same fashion Militec-1 does over untreated).
Cleaning the knife with water after usage and drying promptly is probably your best bet in this instance. IIRC the Becker in 1095c, which, while reactive, is not terribly reactive compared to many other steels. If you constantly use it to prepare food, allowing a patina to develop on the small portion of the exposed edge will help protect it from pitting and is an easy way to get reactive steels to have better corrosion resistance.
There are some food safe protectants, and there are some that are non-toxic although not marketed for usage with food. The non-toxic offerings from Corrosion-X will probably be your best bet if you are really worried about corrosion. Like Eezox, it runs circles around most other products on the market. With that said, it probably is not necessary for this specific application, especially if you go the route of the patina.
Do not remove the coating! It is there to PREVENT the rust that you are worried about!
Thanks! I suppose I need to remove the coating on the knife first.
