Dodo taken apart (Lotsa pics! *56K ALERT*)
'Fine print'
I am in no way responsible if you void your warranty or lose parts during the process of disassembly/reassembly. So don't go crying because Brendan made me lose a part and now I have to pay Spyderco to have it fixed. :rolleyes:
Anyhow, here it goes. It went back to Spyderco to have some screws replaced and a burr removed (which was left there I guess from manufacturing). To begin, the Dodo's one of the Spydercos with the most parts so DO NOT LOSE ANY! Primarily, the parts were immersed in warm, soapy water, then a toothbrush with some more soap was applied to them and they cleaned right up---extremely effective.
*I used a T9 and a T6 driver for the screws, but note...I've had both the pivot screws and clip screws replaced by Spyderco because the previous owner had mauled them up. Thus it may be different from an original Dodo. The screws are the same as the ones on a Manix*
Parts List
-(2) G10 handle scales
-(1) S30V blade
-(2) Pivot screws
-(2) Pivot nuts
-(1) Wire clip
-(1) Ball bearing
-(1) Ball bearing support
-(1) Inner spring
-(1) Outer spring
-(1) Spring support/mid back spacer
-(1) Back spacer
-(2) Teflon washers
-(4) Handle screws
Parts layout
Another view
Blade
Lock components (from left to right: ball bearing, ball bearing support, inner spring, outer spring, spring support/mid back spacer)
Left scale parts
Right scale parts
Lock components assembled (the inner spring slides onto the ball bearing support before the outer spring)
Blade put on
Scale put on
Screws put in
Clip put back on
Best lube ever...used the cloth and wiped down all the parts after cleaning with a toothbrush in warm soapy water...Tuf-Glide was used as assembly lube...all the moving joints were coated in a thin layer of the stuff. (I fully endorse this stuff :))
I forgot to add this in...some WD40 will do wonders to restore that 'black blacker than the blackest to the power of infinity'
Brendan
Great pictures. I always wanted to see the inside of the ball lock. Thanks for the tutorial.:thumbup:
Thanks for the pics. The Dodo is an amazing knife and man.......that ball lock is genius.
:thumbup:
