I have to agree with you that it is a bit of overkill. But since I will still EDC it for a while (honeymoon phase is not completely over yet for me?), some justifications might be needed. I can think of an urburn survival situation. Of course, a lighter tool will do most jobs the Surge can but the metal blade one can carry will give it an edge over others. Also the plier jaws which is so massive and strong and you can realy bet your life on it. One-handed operations for most implements also helps in the survival situation as well as in daily uses (saving you from putting down something to free up your both hands before an implment can deployed). Only new Wave (and its cousins) has this feature...Foilist said:... I decided that it was overkill for my ordinary daily needs...
Sounds like a quality control issue. It has not happened to me yet. But I did need to bend the spring in the eyeglasses screw retainer a bit in order to let the bit sit securely. Well, Leatherman has pretty good warranty policy and customer service. All it takes is one-way shipping fee plus 2 weeks waiting. 2 weeks waiting is the tough part for me. The lever for the sccsors failed (would not engage) and I sent the tool back and got it fixed. It seemed that they either replaced some implements or made some adjustments to them. I found that all blades were all treated and looked like brand new (because I knew I used the blades a lot before sending it back). And tensions of pivot points felt different as well...Matches said:... While reversing the screwdriver bit, the retention spring flew out...
I am glad to hear someone does the same. I guess it is part of what this forum is all about, finding out that you are not the "only" one. Being the only one tends to make one feel somewhat "isolated"...R.D.Hatch said:I carry and use mine daily at work...
