Phillip Patton
- Jul 25, 2005
I'm, er, I mean, this guy I know, is curious.
Phillip it is not one of those things that you stick your head and inhale and it kills you. It kind of builds up in you. The CO binds with your hemogloblin instead of the O2. The hemogloblin likes it better thant the O2 so therefore it just stays there. So it just keeps building up untill you are not getting any oxygen at all and you suffocate. Realize that is a very simple explanation but that is basically the way it works. So get that vent fixed and quit forging with the doors closed.
IIRC, CO is lighter than air so as an extra precaution, you could put in vent to the outside at the highest point. A detector sounds like a must here!
It's heavier then air and will accumulate in low places.
It DOES bind to hemoglobin, displacing O2Hey Guys,
I was just asking because my brother gave me a CO tester awhile ago, and I checked it last time I did some forging. It said 400 ppm, evacuate. I hadn't noticed anything like drowsyness or headaches, but I decided to install a hood to suck the exhaust from my forge, outside. Better safe than sorry. I suppose I've been exposed to low levels of CO for quite awhile, though I only forge with the barn doors closed in cold weather.
Anyway, thanks everyone for your input. I'm glad to know that 400 ppm is probably not going to kill me.Those levels should go way down once I finish the venting system.
Phillip
Good point on that one -if it binds with your hemoglobin instead of 02 over time....what help is a detector going to do.....even if the levels are not really high if there are any levels isn't it going to still just keep building up in your system?......ryan
