- Aug 15, 2013
It's a matter of degree. Since the kick is extending the spring, changing the height will change the position of the spring. Whether or not it noticeable will depend on how much and how good your eyes are.
I think it's important to mention that... flush springs are more an artifact of the hafting process than something meaningful. The springs are ground flush along with the handle material. Since it is the result of grinding, it is not a matter of precision (though it often is mistakenly addressed by collectors that way). In contrast, Victorinox finishes all the parts prior to assembly and the springs are not ground flush. It's done this way for several reasons but the plastic and anodized aluminum handles are not well suited for grinding the backs. I suspect Buck may not grind the backs on the 301 but I'm not 100% sure.
If the parts were cut with such precision that they were flush without grinding, that would be impressive. But they're just ground flush. Similarly, it's not a matter of precision when blades are centered by annealing the tangs and bending the blades straight.
That is a good, complete answer.
