- Aug 27, 2013
I agree. With sharpmaker, H1 is a non-issue (just practice a bit and keep light pressure)
Regarding H1, the serrated versions get work hardened during sharpening and, IMO, cut the best of the fully serrated Spydercos...my Pacific Salt vastly outperforms my FS ZDP Endura.
H1 is the amazing stuff for any avid hunter/fisherman; it makes a good backup or utility knife for bushcrafting too.
I agree with everyone advising to get a good sharpener. The Sharpmaker is a fine tool to get started.
Is it worth getting a 70 dollar sharpening system when I can only have a few knives?
I never understood how the serrated edge h1 gets work hardened but the plain edge doesnt? What key piece of info am I missing? Thanks.
to the op. Sharpmaker was the best money I ever spent prior to using benchstones. Taught me lots....but main thing I learned is knives come from the factory sometimes to often with uneven bevels and at various angles sometimes. If one wants a knife that is easy to sharpen...reprofile the edge and make it even so a quick touch up on the sharpmaker is a easy process.
H-1 does not harden by heat treatment like typical cutlery steels. It hardens by cold work. Something about the brutal process of grinding serrations causes plastic deformation near the cutting edge, which work hardens the steel at/near the edge.
It has been said that the reason H-1 blades are not offered FFG is because grinding the first side flat would harden the blade so much as to make grinding the second side impractically difficult. (Both sides of the hollow grinds are ground at the same time, which avoids this problem.) This leads me to wonder if a flat regrind of a PE Salt blade would harden it enough to see a big difference.
I can't tell you the number of cheap sharpening systems that I've tried from wally world and they just are inadequate. Eventually I got a Sharpmaker, and it's the best $50 that I've spent in a while.
