Good thread, I've never had one fail. I guess I can imagine what the outcome would be. Maybe I've been trusting them too much.
My theory as to why you don't see a lot more lock failures is the fact that a significant portion of these hard use titanium folders are safe queens or pocket queens not really seeing any kinda of use.
It's a common understanding in the knife side of the world that the thicker the lockbar (be it liner or framelock) the better. But I don't this is quite so obvious.
In particular, lockbar thickness as a criteria is ambiguous. Where does the thickness matter? The interface with the tang? The cut out? Average thickness?
If we assume it's the interface, then is the thickness simply wasted in knives with early lockup (that's the vast majority of folders)?
If we look to the bar itself for thickness, ignoring the percentage lockup with the tang, perhaps it makes more sense. But what about the cut out? It seems like the cut out would be the obvious point of failure, and it is, by definition, the thinner part of the lockbar. And if this is so, why don't we much variation in cut out thickness?
If the weak spot is the cut out, why not reinforce that area? Put its back against the g10 scale for instance, instead, as is common, letting the cutout face the scale. Or can we fill in the gap with g10 on a 3d machine scale to reinforce it?
At any rate, assuming that lockbar thickness is a crucial factor in lock integrity, what does that actually mean? That's the central question here.
This is not a theory, it's an opinion. Another opinion could be that you don't see too many of these lock failures because they actually work, work well, and don't fail at the rate your alluding to.
I'd also like a link pointing towards the "fact" that a significant portion of all of these knives sold end up in underwear drawers.
Kai USA produces a lot of frame locks, some more burly than others. We have a warranty department, a lot of knives that come back are used...heavily. A very, very, very small percentage of these frame locks that come back, come back because of a faulty lock. Being a betting man, I'd give odds that this is the case with most brand name manufacturers that produce in this genre. Perhaps this is more telling than the above, perhaps not.
I'd like to say here that it is very easy to draw a conclusion, generalize, and define whatever we are discussing, in this case frame/liner locks, based on your own experiences. Unfortunately this tells only a small tale of the big story. We should all keep that in mind. Opinions are not facts, nor should poster lead members on in their views direction. There are anomalies that can go against the norm's grain almost every time. To exploit them, or make them more than reality is slightly irresponsible.
I'll add that I can only speak from the place where I'm at, and don't speak for any brand(s) other than our own.
Thomas, I didn't say anything about kershaw or zero tolerance so why don't u chill out. Moreover I didn't say anything I was suggesting was fact it was my own theory. I'm not the first person on here to suggest that a lot of these highend hard use knives don't actually see that much use. Also I kinda mentioned the fact that these locks seem to work ok and gave my opion as to why and finally again I nor anyone else touched upon u personally r ur Kai products yet u went on the defensive about ur stuff. My bad for not using opinion And using theory. I can tell u one thing it sill be a cold day in he'll before I ever buy any Kai products. For the record most of my info comes from str either his post or through numerous personal phone calls I've had with him.
