BluntCut MetalWorks
- Apr 28, 2012
... I think that any type of carbide not just vanadium one will have same issue ?
Correct. Shaping carbide and matrix at very thin cross section (the edge) is prone to poor result due to impact, which includes manual sharpening as well. Abrasive cutting points cause apex to deflect away (amt depend on sharpening angle), so end up with more burnishing/impacting than shaping, which could (most likely be 'would') weakened or dislodge carbides and produce wire-edge.
I annotated (2+ years ago) ToddS SEM image of s30v manual sharpened with SiC (iirc) stone. The apex is sub-optimal.
Even using fine diamond plate or stone, such as DMT EE or DMD 12K, where the abrasive penetrating cutting tip is est (or my wag based on experiences) about 0.3um would impact/burnish(due to edge deflection) carbide lead to weakened or tear away from edge. However this type of abrasive would work very well for large carbide and especially huge CrC (in non PM steel). Obviously need to mention: use sharp abrasive = high psi cut point = low burnish/impact.
There is additional complexity of edge trailing or leading mechanic in powered or manual sharpening. Done OTing..
