*SOLD* Dog Tooth (Brad Zinker) Cocobolo Wood S35VN
$99.00
Knife is in excellent condition. Original Edge. (Stropped Only).
Cleaned and lubed with very good action.
Free Soft Pouch, Not OEM with Knife.
If you need higher resolution photos please let me know...I can send them. Thanks.
(Specs Below)
$99.00
(Specs Below)
- Zinker Standout: Introducing the newest version of the Dogtooth: a pocket-friendly liner lock with equal emphasis on function and form for a more uniformly shaped handle and an overall cleaner look. 3.3-inch wharncliffe blade made from S35VN steel.
- Maximum Control: The Dogtooth’s wharncliffe blade is made for control. The nearly straight cutting edge is easy to guide through material with accuracy, and the fine tip excels in detailed cuts and makes quick work of everyday tasks
- Minimum Bulk: Shaped like a teardrop the handle is visually pleasing and comfy to hold, cocobolo wood. Overall weight just 2.4oz, disappearing into the pocket with ease.
- Brad Zinker: If you like slim knives, you need to know Brad Zinker. Brad is a voting member of the Knifemakers’ Guild with a passion for slender designs. His philosophy is simple, that knives should never be a strain or hindrance to their owner
- S35VN Steel: Developed by Crucible Industries S35VN is perhaps the most balanced blade steel ever created in terms of all-around performance. CPM process produces a steel characterized by superior stability, grindability, and toughness
