- Sep 10, 2010
I can definitely see how the NMFBM would be the better chopper with the convex grind and its length. I want to see the KZ 2 LE in action
KalEl, why not try selling the CGDF and pitch a little money into getting a B11 ? Those two are closer so to speak and then keep the Zilla ... having both a CGDF and a B11 is less of a "range" of chopping ability compared to hanging onto the KZII.
I know what you mean about the KZII being able to "turn" in your grip if you hold it "centrally" using the middle palm swell ... one of the reasons I want to swap out the grips for a TTKZ style which has a better "locked in" feel is because the front of the grip has a longer and deeper swell and so has the rear ... therefore stops your hand want to "slide" when impacting on the wood.
You can run a lanyard through the first ( from the front ) eye hole on the grip and this helps lock in your grip ... but bear in mind if you catch the blade on overhead branches when swinging and it dislodges in your grip a lanyard can cause it to still be a "lose danger" .... whether or not to use a lanyard is a difficult call .... because equally speaking dropping the knife at the wrong point in a swing would still be dangerous .... the simple rule with the KZ's (or any chopper really) is to watch your feet and leg position and your swinging clearance carefully .... personally I prefer no lanyard but each to their own ....
For what it is worth technique wise .... if I am going to chop and section a log ... such as on a fallen tree where I have to take the task as it is presented .... I use other chopped (thick) branches and place them inside my line of swing "stance wise" to act as "backstops" if I consider there is any chance that swinging "low" may on a glanced off strike run the risk of catching my legs .... so far so good and it has never happened .... but better to be safe than sorry ....
