Thats a great question Pat !
It took a LONG time and lots of belts experimenting but I've finally settled in with a process that works for me. Still subject to change of course when Nick shows me the error of my ways
I'll grind roughly 75% pre HT.
I'll grind it right to where I want it with a used 50x blaze then refine the scratches at 80x then 220x. Then hand sand the entire perimeter of the blade at 220x so the scratches run in line with the spine and edge not across it.
Post HT.
I'll get back to completely clean steel with a used 50x Blaze and get to maybe 80% ground.
Depending on the shape of my 50x I'll either finish or get a new one and grind to roughly 95% BUT staying out of my plunge with the 50x just a little. I get my edge right to finished thickness with the 50x
After the 50x I go to a BRAND NEW 80x J-Flex. I'm hardly moving my grinds at all with the 80x. A little towards the spine and move the plunge back just a tiny bit to true it up. Sometimes, especially with larger blades, I find I need to grab another new 80x for the other side of the blade. I want a sharp 80x that CUTS and try my best to finish with a perfect pass from the plunge to the tip and flat from edge to spine.
I've found that for me the condition of my grinds at 80x determine the difficulty for finishing the blade the rest of the way. I won't move on until I'm golden at 80x.
I go from 80x right to a BRAND NEW 220x J-Flex- If I was truly good at 80x it only takes a couple passes on the 220 to refine the scratches.
-I never could find love for a 120x belt. I tried them a few times but just found them not necessary to go from 80x to 220x. I see so many others use the 120's I've been thinking about giving them another shot even though this method works pretty well for me.
After the 220x I'll throw a sheet of 320x on the disc grinder and make sure my flats are flat and save myself a little time hand sanding.
Start hand sanding at 320x and go from there to desired finish.
I didn't always do it this way. I used to do alot more grinding at 80x. As your grinding confidence and skill improve you can go further with a rougher belt. The fear of a late stage whoop-de-do with a rough belt has subsided these days so I go for it without worry at 50x.
Hope this helps Buddy !
Nick, Please don't pass on an oppertunity to show me the errors of my ways !!! I love advice and I'm willing to give anything a try.... at least once
Have a great day fellas ! Josh
