Dollar Store Survival
I love Blackjack.....my wife and kids don't care for it which means it might actually be around for more than a day or two.
I was able to make it out today to try some of my Dollar Store finds and put together a shelter. I chose an area somewhat off the beaten path that also has several large piles of cut branches from some of the work the Forest Preserve has done in this area. They would provide an ample supply of firewood and I probably would have been able to put this together without the saw, but I did want to try the saw out anyway.
The Saw
Kind of surprised at how well it worked. The blade is pretty thin and flexes more than a higher quality piece but it held together and did its job. I used it to not only trim the poles to length but also to remove any unwanted branches and twigs. While I don't think this will be replacing my other saws, it did at least "work better than nothing" and doesn't seem to have dulled significantly after 20 or more cuts through the green Buckthorn I used for the bulk of the shelter.
The Knife
To call it a knife is generous, I would say so far its more of a "knife shaped object". I tried to use it to make some flats on the poles and it failed miserably. The blade did make several cuts in the rope but that was about it. So far, I am not quite sure if this even hits the "better than nothing" mark but we will see.
The Shelter
As I mentioned above, I used the saw to prepare several poles and cross-braces to construct the frame of the shelter from the abundant Buckthorn (an invasive species here). I then used the cable ties and rope to put things together. The cable ties were somewhat handy, but they are not very strong and I broke 8 or 10 of them putting things together. The rope actually worked well, it holds a knot and was easy to handle.
The frame
Once the frame was complete, I unpackaged the plastic "tarp" and spread it over the frame, using dead branches and some logs from the pile to hold the plastic down. I did not want to puncture the tarp as it is less than 1 mil thick and I did manage to spread it out without tearing or puncturing it.
The front
While I will not actually be sleeping in it, I did climb in to check things out. I had more than enough space to fully lay down and it was actually kind of cozy in there.
A view from the interior
I will be returning to shore things up a bit, build the fire area and enjoy my stew. I also plan on trying to conceal it a bit more as I had a limited amount of time today.
Great thread! Goodwill is another great place to find deals. I just bought a large, heavy-duty "Realtree" pattern poncho for five bucks at my local Goodwill. I have friends who have found great wool sweaters there too.
I made it back out to the shelter today. I wanted to check on it to see how it was standing up to the snow we got. I was concerned that the snow may have damaged the plastic as it is pretty thin.
It actually made it through really well. The front edge pulled back, but was easily repaired and there was no real damage at all.
Fire
I gathered a "tinder bouquet" of dried grasses and plants that I knocked the snow off of.
Using a single match, the bundle lit easily. Of the items purchased, this eight pack of matches is really a great deal. While they are not waterproof, simple wooden matches like these have served countless outdoorsman for 100's of years. There is something nostalgic about carrying a small box of matches in a coat pocket and starting a nice fire to warm yourself by.
I climbed into the shelter, pushed up on the plastic to dump off the snow and enjoyed the growing blaze. I was surprised at how even this small fire could heat the open-fronted shelter. It was very comfortable inside and the combination of fire, wool and fleece kept me toasty.
While I sat inside, watching the flames and falling snow, I was struck by the urge to try and write down what the moment meant to me, why I was there in the woods, under a sheet of plastic, on a Tuesday afternoon. I pulled out my little notebook and jotted this down. I trust you will induldge me while I "wax poetic".......These moments stolen from life's responsibilities to commune with the solitude of the natural world shall never be tallied against my time on this earth. Fate looks away and suspends his final visit while I hide in the coat tails of Mother Nature. This is why I seek the trees, the dirt and the sky so that, for a fleeting second, I may know my place in this grand majesty.
Thanks for tagging along.
Hi outdoorsfan -
Sweet man!
best regards -
mqqn
I went out to check on the shelter today as I was curious to see how it had faired after a week outside. We've had a few snow showers and temps ranging from the 30's down to the teens for the past week. As I approached, I could see that something was amiss. Although there were no tracks, I could see that someone had found the shelter and cut the guy ropes.
All four ropes were cut...
The front had peeled back because it was no longer held by the ropes but, to my surprise, the shelter still stood and could have easily been repaired. From the lack of tracks, it had stood for at least a day like this. I decided to dismantle it at this point and remove the waste. The JK Sparkler made short work of the pole bindings and the whole thing was down within a few minutes.
The Plastic
This was one of the surprise items for me as I thought there was no way a plastic painting tarp from the Dollar Store would last a week in the winter woods. While I was taking things down, I was very rough with the plastic sheet and it was actually somewhat durable. While it doesn't rival even a cheap poly tarp in toughness, it did work to provide a dry place out of the elements. This might be an item to consider as it is cheap, lightweight and could prove to be a nice thing to have in a car kit or backpack to use as a shelter, body wrap, solar still or temporary cover.
The Saw
It wouldn't replace your Silky or even a Sierra saw but, again, kind of a surprising tool for $1. It's basically a light, plastic handled pruning saw that probably wouldn't hold up to alot of heavy cutting, it was more than robust enough to cut and prep poles for the shelter and would handle branches and small logs up to maybe 4-6". The handle was comfortable in use and it included a plastic edge guard that is reusable. As a back-up, kit or car item it is worth considering if you find them.
The Matches
As said earlier, matches are basically matches, but with 8 packs of 32 wooden matches, this was another item to consider picking up. As an alternate or secondary method of starting a fire these have a place. I put packs in my jacket pockets, backpack, both cars and still had some leftover for my woods bag and pocket kit. I like to keep mulitiple forms of fire available and I prefer these to a lighter for firestarting. Couple these with a firesteel and some reliable tinder and you would have a fairly foolproof fire starting compliment.
The Knife
Total garbage. After playing around with it a bit, I will give it "better than nothing" but that lid from the stew can would make a better knife. I would pick up a $.40 kitchen knife from a thift store instead of this. The tools were weak and border on useless, the blade threatened to snap under light cutting pressure. Leave the knife and buy two tarps or some extra matches.
The Tie Wraps
Maybe not as junky as the knife and they did hold the shelter together for a week but I could have easily got by making the shelter with the rope alone. They might be ok for organizing the cables on your PC but not too much more than that. Buy two lengths of rope.
The Water
This is another item that, like the matches, is pretty straightforward. I do like the 6 pack packaging and it is another nice item for the car or pack. I understand the thinking behind the much quoted "gallon of water per person, per day" but that can get pretty heavy. This 6 pack could provide water for at least a day or more and it stows easily and packs well.
The Rope
The rope was better than exepected. Easy to handle and tie, weather resistant and, at $1 for 50', pretty economical. In the car, it could be a back up and serve as a utility item to hold a trunk lid down ar other light tying. With the strands separated, you could have up to 150' of reasonably strong twine to bind and build with. It's not paracord but it ties stuff up.
The Stew
Haven't had the pleasure yet.....I will have to get back to you on it.
The Verdict
Some of the items really did exceed my expectations and some were just junk, but I do think I found some things that could have a spot in the pack or car kit. There are other items, hand sanitizer, first aid kits, baggies, containers and many more that may be worth consideration as you put together or update your own kits.
This reminds me that I need to get out to do more shopping. As for the thrift store knife for $0.40, mine cost $0.10. :D
Love the line of your thoughts "poetry". I think we all need to get away from this concrete jungle of ours and spend a few days away from everything electronic. View what the great Creator has made then come back and meet up with reality again. I always hate coming back from a good campout.
I almost forgot. Good job with the non tools. It would have kept the snow off of you by one of the photos I saw whey your returned to your shelter.
cajun
Couldn't agree with you more my friend. :)
I am a Boy Scout leader and we took our 14-15 year olds out on a survival camp a few years back. All they could bring was what they had in their pockets at church when we announced the camp, along with 1 other item each that could not be separated into separate parts, i.e. a fishing pole is separate from the reel, separate from the line, separate from the hooks, etc. I think one in 8 had a pocket knife in his pocket. Great camp, 3 days and they were cold and hungry, but learned someting. Last day we gave them a live chicken. That was fun. Joe
Wow, 3 days on just what's in your pockets would be tough. I wouldn't want to be that chicken though!
That would be tough! I just did a pocket inventory, this is what I carry everyday.
Either a Victorinox Cadet or a Buck Stockman
Victorinox Classic on keychain
4 way screwdriver on keychain
Aspirin in capsule on keychain
Eyeglass repair kit in capsule on keychain
Photon flashlight on keychain
Bandaids and butterfly bandaids in wallet
Needle and thread in wallet
3/16" diameter firesteel in wallet
Lighter in pants pocket
Lighter in shirt pocket
Large red bandana in back pocket
Hey, I might do ok! :D
What a great thread about creative thinking,and making due with what's available within your means!I enjoyed it, thanks!
Here's an old one that some of the newer guys may have missed. I actually submitted this as an article idea to Backwoodsman magazine and they liked it but I've never gotten around to writing it. Maybe I will put some time in and see if I can get them to publish it.
