Short-term update/review:
Been using her around the house for any number of things -- rope, string, cardboard.
The high grind does in fact work a wonder on thick cardboard.
The original edge angles were around 24 on one side and 30deg on the other. I took them down to about 22 on each side and mirror polished them.
It's now a mean cutting machine -- not quite rivalling a kitchen knife or a reprofiled 710HS (what does?) but still very impressive. Slices, push cuts, pierces extremely well.
The lock is doing a little bizarrely. First, it's stopped "sticking". There is no galling; I think the lockbar tension is just right. I like a little stickiness because it prevents the lock from sliding under spine pressure. However, any tighter and there's too much retarding force on the action.
That brings me to my second point: the lockup point has moved from around 50% to 75% in about a week of light to moderate use (and I did not play much with the Robo.) Now, I know that Sebs usually lock around 75% to 100%+ (that frightens me) and there's absolutely no blade play now that I fixed the spacer issue.
I'm guessing that Camilllus will do whatever necessary should the lockup go past 100% and start showing any play.
-Jon
