- Dec 31, 2014
Apparently both bits were used for limbing? "Once a tree was on the ground, a different crew of men called "swampers" would remove limbs from the tree so it could be cut into lengths. The swampers were also responsible for clearing underbrush before a tree was felled and also constructed logging roads in the pineries. (Because, swamping required less skill than felling, swampers were paid less than fellers.) A Swamping Pattern axe was different than that used by fellers. The bit on a "swamping" axe had a different profile than a felling axe. Designed for limbing, the bit was usually wider and more rounded than a felling axe of similar size and weight." http://midmichigannatureandscience.blogspot.com/2013/08/logging-tools-part-1-axe-and-saw.html
