Liu Kang
BANNED
- Jul 20, 2007
Ok, been looking for this one knife, I think it might be my grail knife, it's the meaner street limited edition for a while. It was my first knife and I sold it before knowing what a Busse even was. Well, that lead me to search what a Busse was and I'm here today because of it. So it's sorta my grail knife to get because it got me started on Busse and I owe a lot to that one knife, so been trying to get that one back for a while now.
Well, it turns out that's sort of a hard knife to come by, so anyway, I got a hold of a sterile original meaner with a double cut flat ground. So the only reason I even bought it was cause I know the double ground knifes turn into satin a whole lot easier then coated blades. I was going to send it to the shop but well, I was messing around with a different double cut blade I had and it didn't turn out bad so I took 2000 grit sandpaper and went at this meaner. I only did one side so you can see the difference. So if I sorta mess it up or don't like what I do to it, I figured I send it back to the shop and have them turn it into satin for me. It didn't turn out so bad, I sorta like it. It's not the same as a factory satin though, mine is not as silver or ight in color but is so much smoother then the factory satin finish. The top two pictures are of just the blade sanded down, the bottom three are of the pictures of the factory double cut finish.
So is there a right way to do this? Like the grit of the sandpaper, from what to what? Anyone have any advise?
The other thing I was thinking, will I like this more then my other Busse knife because I worked on it myself and put a little bit of myself into it or will I like the factory Busse work better? What have you done and what do you think you like more? What do you guys think?
