dovetail cutter
Hey guy's,
Quick question regarding dovetail cutters: what kind of speeds should i be running them at? i'm using them to dovetail in 6al4v titanium. i baught a couple cobalt cutters which are 3/4". i ran my mill very slow 200 rpm because any faster just did'nt feel right. but i wore both out very fast.
Any reccomendations of which to buy and how to run them??
I have found that carbide doesn't last much longer in this application, and 200 RPM sounds okay for 3/4" in titanium. The only thing I can think to recommend is be sure to feed hard enough and keep it cool and don't try to take it all off in one pass.
A 3/4" cutter in titanium should be fed at least .003" per flute, and preferably more. Otherwise the titanium (which is strong, but flexible) will move, but not cut - leading to high cutter wear. Also, titanium conducts heat poorly, and the shape of a dovetail cutter is such that the tips can get overheated easily. If so, use flood coolant.
Were you just milling an "undercut" on one edge of a bolster or were you trying to create an actual dovetail ? The reason I ask is that if the latter is the case (a dovetail), standard procedure is to first buzz an endmill through. I use the dovetail cutter to remove only the undercut area of the dovetails geometry.
Your RPM sounds ok. When I'm running one in Ti or SS I can almost count the flutes as the tool spins .............. almost, but not quite ;)
So much of the machining I do now is done intuitively, including speeds & feeds,.......... gauged only by the experience I've acquired over the last 30 years. Sorry I can't be of more help :o
If you want formulas, code or high tech-"state of art"-"cutting edge" ;) advice & help, Nathan the Machinist is THE MAN :thumbup: :thumbup:
Edited to add : See ............. at my age I even type too slow. Nathan beat me to the punch :D
Ok, thank you guys!!
Yes, i'm only doing an undercut of the bolster area's. i remove the bulk of the TI with either a 1/2" or 3/4" endmill. i was using cobalt but they dont last long in the TI so i just picked up a carbide hanita to try out. so i should probably just use standard HSS dovetail cutters with slow speeds?? where do you guys buy your dovetail cutters?
In an industrial mill that weighs four tons, and with engineered speed, feed and DOC, the carbide will outlast the HSS 5:1 and increase productivity. But in a home shop they're probably going to give similar service, and the HSS costs a lot less.
You got a 3/4" carbide Hanita? That is good quality industrial production tooling. What did that set you back?
I buy tooling at a lot of different places, but one that you would have heard of is MSC. My shop has a 30% discount there, but they frequently give that discount (or better) as a "daily special" if you look at the site in the mornings.
Perhaps a dumb comment, but..
If you're milling the undercut for your bolster - why not simply hold the loose bolster at an angle and mill it with a standard end mill? I must be missing something
Nathan, the Hanita is only a 1/2". i got it off e-bay for $16 :)
I machine the whole handle.., i start with 3/16 TI and machine out approx 1/8 in several passes. i was using cobalt roughing endmills and they were burnt out after machining maybe 6 handles. so i figure carbide gotta last a bit longer?
