Some things better....some things the same....some things - just different.
For example, the Dozier runs on DC rather than AC like the KMG.
I had a PentraDrive controller and 2HP Baldor motor on the KMG too...so I feel I can make a fair comparison.
Both will bog down if you try hard enough. The Dozier bogs down more easily...BUT...ramps back up readily.
The AC KMG...when it bogs down literally rebounds...like a hiccup...slap on the face, etc. thinks a second, then ramps up from low rpm.
The DC controller just slows down and speeds back up. Much harder to make it actually "hiccup"...but it took some getting used to.
that would be an example of "different".
Now...where the Dozier shines is slack-belt handle shaping. See that arm sticking up in the back? I can rotate it down, put a small wheel on it...and then it's slack belt all the way back to the drive wheel.
The KMG, imho, has a better flat platen setup. Neither is very good at allowing goofy-side profiling (hanging the blade off the platen to do inner curves...HAS to be done on the right side). But the KMG does have a little more room before you hit the tooling arm.
But the real shine comes from the ease at setting up an angled platen. The Dozier comes standard with and adjustable angle platen. I have two more tooling arms headed my way so I can have a flat tool rest as well as a couple angled rests.
Honestly, that's probably one of my top-three reasons for upgrading. I use the angled rest a LOT....and I don't have time to build special tooling arms...and if I'm gonna buy a reticulating arm...might as well put the money towards a new grinder.
The Dozier also is on a stand rather than on the bench. I can move it around....there's room for ducting around it...cleaner all around.
One huge difference is the direct-drive feature vs. the pulley/v-belt system of the KMG.
Don't misunderstand...I loved my KMG and worked it like a dog...
But I'm at a point where I need greater versatility...so I went with the Dozier instead.
