- Dec 19, 2002
DPx HEAT/ F First Run, Sleipner Steel, G-10 Handle
Suggested Retail: $199.95
Our Price: $149.95
You Save: $50.00
Free Ground Shipping on $99.00 or more orders.
http://www.knifeworks.com/dpxheatffirstrunsleipnersteelg-10handle.aspx
In 2010 Robert Young Pelton took his original 3" 1095 Shon Rowen-made fixed survival blade and turned it into a brutal use locking folder. He demanded the best, American made Ti aerospace grade titanium alloy and Olive Drab G10 to create an integral, no scale frame. Then he added a D2 Tool Steel blade, mil spec coated it and had it machined in Northern Italy the same place they make Ferraris, Lamborghinis and Ducatis.
He added a hex driver, low profile clip and glass breaker. The knife also features the same bottle opener notch premiered on the fixed blade which, on a folder, doubles as a "quick open" feature. It continues to make experienced knife users rethink what they can get in a hand assembled, user designed, no excuses survival tool.
But there is another group that want the same no expense spared approach to the under 3" inch blade. Law enforcement, military and first responders wanted less blade, more knife. And they still wanted the glass breaker, rapid deployment, non lethal ergonomic grip and quality. So the Hostile Environment At Hand Tool (HEAT) was born.
The DPx Gear HEAT/F is as much blade as you need, in a beefy, pocket friendly package. Whats different? We dropped the blade size but not the blade thickness leaving the business end of a sword grind that snaps quickly into action. We eliminated the hex drive slot and the aluminum back spacer but kept that confident, beefy feel that HEST/F folder owners love.
Then we made the blade out of Sleipner steel. The same steel used in commercial meat processing machines to give you a cutting edge that lasts well past what you might be used to.
Finally we backed it with the same no nonsense, no questions asked warranty that Robert Young Pelton demands. Serialized and engraved with "First Run" on the spine of the blade so you know you're a part of DPx history. First Run is limited to a total of 250 pieces.
Specifications:
Blade Length: 2.26"
Blade Thickness: 0.18"
Handle Color: Black
Handle Material: G10
Overall Length: 6.24"
Rockwell Hardness: 59
Configuration: Right-handed
Weight: 4.15 oz.
Our Price: $149.95
You Save: $50.00
Specifications:
Blade Length: 2.26"
Handle Color: Black
Weight: 4.15 oz.
