- Jun 4, 2010
"Toothy edges don't last"
Who told you that?
Didn't get it from me....
Who told you that?
Fred,
In my own informal testing, I found that a 4 micron finish (Norax belt) compared to a 100 micron finish (Norax belt) had dramatically different edge holding. What was my testing? Opening cardboard boxes, sealed with tape at my job. I found a 2x to 3x increase in the ability to keep a "box cutting edge" when I switched to the more coarse edge.
I know you are a smart guy, a knife enthusiast, and a skilled knife maker. But I wonder if you've done any real world type testing, that resembles mine in any way. Meaning, cutting something that's somewhat the same, using the exact same blade, and different finishes. Rope cutting, slicing cardboard, etc, to me are interesting, but they seem flawed. Because no one does that with a knife blade. No one cuts rope into 1/2 sections hundreds of times.
I did my test just as part of doing my job. I wanted my edge to last longer between sharpening sessions. Moving to a more coarse edge finish did this and it was rather obvious. But that's just my VERY INFORMAL results. Very un-scientific. But still valid I think.
Thanks for reading.
Brian.
What is a toothy edge? There's no standard I don't think.
To me a toothy edge is one that is not refined after the burr is removed by breaking or snapping it off. When I work that edge to refine it then its no longer toothy. I have not found that edge to stand up; the apex is what remains after the burr is removed and that edge is extremely chippy.
I know in my profession that a less refined edge works better cutting certain proteins and vegetables, and as a hobbyist that some steels perform better at a lower grit than others. We can start getting wrapped up in the semantics of what defines toothy and go round and round but a more refined edge is not always better.
Russ
As I said in my post, I tested with a 100 micron belt to finish my edge. That was my coarse (or toothy) edge finish. My finer finished edge was doine with a 4 micron belt.
I would not have used that definition myself. From what I understand, a "toothy edge" is one that is finished with a more coarse abrasive. How coarse is the end of toothy and the beginning of "fine" ? Who knows. I'd say the transition zone for me personally is around 600 to 800 grit. That's where toothy becomes refined. Like you said, the term itself isn't very specific. But I put numbers to my test so we can talk about specifics.
I can understand, with your definition, that this type of "burr ripped off" edge would have all kinds of weak pieces and parts stuck to the apex that wouldn't hold up to much use at all. Again, I don't think most people here are using that definition when they use the term "toothy edge".
Brian.
Chris "Anagarika";16523099 said:DBH,
Polished toothy .... You mean like Jason's recommendation DMT C and strop on 1 micron diamond paste ?
Chris, that was one instance I was alluding to. M390 many be my favorite folder steel and works like a charm sharpened this way.
The edge lasts too... one of my elmax folders from Alan Davis also gets this finish and cuts forever, part of that is his grind and HT.
Just got a bluntcut metalworks in cts xhp, if it ever dulls I am gonna try this strategy on it.
Russ
My own testing showed exactly what I'd come to believe informally.
A toothy edge lasts a lot longer when the primary cutting mechanism is a draw, a fine edge lasts longer when the primary mechanism is pressure on a static edge.
For a variety of chores, something in between is best. There is no blanket "best edge" strategy, only compromises based on what the tool is expected to do.
http://www.bladeforums.com/forums/showthread.php/1368637-BCMWn690?highlight=BCMWn690
Can you explain why you believe this is the case?
Thanks, Fred
