- May 3, 2006
Hand sanding can be relaxing or the worst possible process on earth depending on your mood, the steel, and what tunes you have on in the background!
Oh soooo true! But it also depends on the kind of drink I'm having
Any clues of what can I do here? I guess I need a perfectly flat surface for gluing on the handles... (they will be pinned as well with two or three 6mm brass rods). I don't want them to pop off.
Agreed. I never leave blades like that, the pic was taken while I was working on it. I only overhang the tip on rare occasions, and usually support the whole blade to avoid flex anyways. Thanks for the heads-up, though!
Oh man...I'm so-freakin-far from being good enough to give adviceBut here's some points:
- I started with precision ground steel (O1) - It helped a bit..
