- Jun 17, 2010
Hey guys,
I am currently working on a hunting style knife that I would like to gift to a very close friend. The steel is 1095, dimensions are .130in thick, 7.5in overall length, plunge line to tip is 3.5in, and the blade width is 1.069in. The blade is a Full Flat grind and the spine tapers from .130 at the plunge to .050 at the tip. I have left the edge at .075 nearest the ricasso but its .050 at the tip prior to heat treat. My question is concerning heat treatment.
I have an electric heat treating oven, although it does not have digital temperature control. The manufacturer calls it "infinitely adjustable", i played around with all the settings on the dial and have figured out where the dial needs to be to hold certain temperatures. The accuracy of the oven is +/- 20 degrees Fahrenheit.
I wanted to see what you more experienced knife makers think about the process I would like to attempt prior to me attempting it. The biggest thing I am concerned about is that I plan to quench in Brine Water. I got a brine recipe out of the Machinists Bible, it says to add 3/4LB rock salt per gallon of water and allow to dissolve for 2 hours, stirring every half hour or so. I plan to use 5 gallons of water, and 3.75LB of rock salt. I have used canola oil on 1095, blade didn't crack but I did not feel I obtained maximum hardness. I have also tried a brine solution although I used standard table salt and lets just say I was unsuccessful on multiple blades.
I plan to follow this procedure:
Slowly heat knife up to 1550*F, once there let soak for 10 minutes, then remove and allow to Air Cool. (Normalize)
Once knife and Oven are room temperature i plan to place knife back in oven and heat to 1500*F, once temperature is reached I plan to Soak for 20 minutes and Quench in Brine Solution.
I then plan on tempering in a toaster oven at 400*F for two 1 hour cycles. I plan to achieve a final hardness of 58-60.
Questions:
A) Is the +/- 20 degree oven accuracy going to hurt me?
B) Do you feel I left enough thickness at the edge to prevent warping/cracking?
C) Does my brine solution recipe sound accurate?
D) What do you think of my procedure? What would you change?
E) On a blade of this size is there a need to soften the handle of the blade, or will I be ok leaving it the same hardness through out?
I appreciate everything you guys do for us! Thank you!
Questions:
