- Mar 8, 2008
Aluminum oxide and silicon carbide both come in a variety of grades, and different classifications of bond are also subject to a lot of variations, including specific composition, the pressure during molding, firing temperature, availability of oxygen during firing and how that reacts with the abrasive and binder, the grit/bond ratio, and so on. But nearly all synthetic Japanese water stones are using aluminum oxide as the abrasive, with most of the remainder being silicon carbide. Most of those stones are either a vitrified bond, producing a stone that works best when soaked and sheds grit from pressure that breaks the weak bond used, or a magnesia bond which breaks down with exposure to water, producing the shedding action by that method. Neither of those are enhanced by the presence of wrought iron, which is the crux of what I've been saying the whole time.
I do hope this doesn't come off as overly contentious, it's just that I've put a lot of time both in technical research and experimentation into figuring out how abrasives are formulated and function, and what variables influence what factors. This is all a side point to the fact that you like how they work, including the sensation/feedback of the wrought iron being abraded by a soft stone.
Slurry-forming stones are excellent as an intermediary polishing stone, as the free grains plowing into the apex keep it from forming a wire edge or tenacious burr, freeing you from having to fight it during final honing. But for the final step a hard stone usually works best for creating a crisp apex, and for that stage I like to use sintered ceramics. Hard natural stones were typically prized for that stage for the same reason.
