- Aug 31, 2013
I often hear people claim that a certain knife is far too big to use when cleaning small game. To this I say "Phuey!" In fact I prefer a big blade for the job because of its chopping ability. So if you're interested, keep on scrolling down. If blood and guts makes you squeemish, turn back right now.
Step 1. Chop off limbs right above the knees.
Step 2. Lop off the head. Chop if you're a good shot with your blade. I useually put the blade to the neck and push it through.
Step 3. Pinch the hide in the middle of the back and cut it.
Step 4. Grab both sides of the cut and pull. The hide will come off like two gloves.
Step 5. Pinch the membrane at the bottom of the abdomen, lay the blade flat, cut and pull up on the membrane at the same time. This method greatly reduces the chance of puncturing the innards as compared to using the tip of a small blade.
This will leave all of the lower innards wide open and easy to remove.
Step 6. Push the blade through the sternum, up towards the neck. This will split the ribcage and allow easy access to the heart and lungs.
Step 7. Put the blade against the pelvic bone and give it a sharp rap with your hand. This will allow you to get the last bits of nasty stuff out of the critter.
Step 7. Tell the naysayers that your TGLB, Battle Mistress, etc., etc. is the perfect size for cleaning small game. :thumbup:
