- Jan 26, 2018
hello everybody. what drill bits are good for drilling through steel? I was using carbide drill bits but my last one the tip got deformed a little and chipped when I was drilling through some 1/4 5160 steel.
thanksCobalt, hss-co
I bought some bits from KnKut a year ago and thats all I use since on clean metal. Top notch bits. If I’m rough drilling crap, I’ll use cheap bits.hello everybody. what drill bits are good for drilling through steel? I was using carbide drill bits but my last one the tip got deformed a little and chipped when I was drilling through some 1/4 5160 steel.
thanksI bought some bits from KnKut a year ago and thats all I use since on clean metal. Top notch bits. If I’m rough drilling crap, I’ll use cheap bits.
ok thanksCarbide drill bits are expensive, I buy Miliwaukee cobalt drill bits at Home Depot for under $5.
thankslook for M42 or M35 cobalt HSS bits. use a drill press. buy "screw" length bits, they are shorter and have less runout(more runout more oblong hole). just because a bit is carbide does not make it ok for steel. read the description before buying, some are for non-steel metals or wood or plastic.
Best kept secret in the knife making world. Shorter bits work so much better.look for M42 or M35 cobalt HSS bits. use a drill press. buy "screw" length bits, they are shorter and have less runout(more runout more oblong hole). just because a bit is carbide does not make it ok for steel. read the description before buying, some are for non-steel metals or wood or plastic.
it will work it guess. "screw machine" bits are usually cheaper than 'jobber' length. for larger holes, 1/4" and up, I like "maintenance" bits which come with 3 machined flats so it chucks up extra tight.I know it’s not optimal, and can damage the flutes cutting edge, but couldn’t you just chuck a regular bit higher up so only a smaller amount is sticking out? I use the thick countersink bits to start/locate my holes as they don’t flex at all. The ones I use most have a 1/8” tip amd 1/3” shaft/body.
No, I wont chuck up on the flutes. Just too easy to get the screw machine bits.I know it’s not optimal, and can damage the flutes cutting edge, but couldn’t you just chuck a regular bit higher up so only a smaller amount is sticking out?
the 3 jaws chuck wont grip enough surface area of the hardened flutes (drillbit shanks are not hardened, chuck jaws are btw.) plus the critical point where the jaws end and bit sticks out wont have good radial support leading to wobble.but couldn’t you just chuck a regular bit higher up so only a smaller amount is sticking out?
