- Feb 27, 2006
wow i had no idea the chuck could pop off. thanks for the info. i had noticed cutting through a guard with side motion was not easy for the (cheap home depot) drill press by the sound of it. so i use the tip of the mill like a drill bit and drill out as much as i can then just use the side motion to clean the points left between the holes. i noticed a carbide mill will not try to wander into the next hole like a drill bit, so you can space the holes really close. i am assuming using the end mill like a drill bit is ok, since there is a cutting tip, but i could be wrong.
