Dang Marcel I hope you a speedy recovery..
OK here I go again
I'm one of those that do not clamp things down if it's a hole under 5/16" or so.... knock on wood. I'bve drilled this way as large as 1/2"
but for years now I've had practice and a feel for it,, .. I do set up a dead block now more often , so I do think about it at all time and what can happen.. the two most pragmatic times are enlarging a hole and when the drill brakes through
( as said the steel wants to lift) and then twist into the bit making problems worse), these are very dangerous times. I also hand tighten the chuck so the bit will give under less torque... I do not suggest anyone to do this..
it's like they say on stunt junks don't try this at home people
one day you may see me post the same as Marcel is
why do I do this STILL? a man most of us all know, said once,
"no man alive can hold something down by hand while drilling a 5/16" hole in it.
I think about that each time I drill one..
I know I'm a goof
But it's a matter of being totally in control of what you are doing..total control of the feel for that drill and press, don't try this at home people to prove anything..
I've done this years before hearing that said.. but still I can't help but smile each time now
heal fast Marcel.. we'll share some war stories at the next hammer in
