Hi- first post in this section, and a very newbie one at that so be nice
I came across what looked like a nice older drill press, but from Taiwan. Price was right so I purchased the beast! It's an AMT 4592 power drill press and weights about 85-100lbs. The base is thick and heavy as crap, as is the table. The table also locks in place with no wobble. When the drill is running, the whole press will wobble a bit.
Could this wobble effect hole cutting? Should it be bolted down to make the whole press more firm?
Now the real issue is, the chuck seems to wobble just a bit, perhaps an 1/8in bit makes a 5/32in hole, so 1/32 off.
Is that too much for making holes in knife steel? I'd like to make 1/8, 1/4, and possibly 1/2 holes through no thicker than 1/4 steel... With the wobble is it possible?
Are cobalt bits the way to go or too brittle?
Does the knife have to be clamped down to help avoid bit breakage? (I'm aware I need to use a "fence" to keep knife from spinning.)
Should this AMT be a huge paper weight or can it be used still?
And last question, can I get a replacement chuck that would work with this drill to correct my problem?
Ok very last question, I can't find much on this drill press on the net or this forum so I had to post. Only thing I've found is the last year it was made, which is 1998. Any idea where to find parts???
Ok seriously the last question, does anyone know of anyone that has one?
Thanks for all for reading my slop, and if you have any help, I appreciate your comments! ciao ;]
