Hi All,
I need to drill several blades of thin 15n20. The steel is annealed from Aldo, was easy to cut and grind, but when I went to drill holes, failure. I managed to drill one, mostly using a bad attitude and sacrificing a couple of bits. I took a break for a couple of days and went to drill more last night using a cobalt bit and a carbide bit on partial holes I already failed to drill. I was patient, I used a cobalt bit first, was patient and stopped when I thought it might overheat. Nothing was happening anyway. I moved on to the carbide(s), the longer one snapped at the tip (little too much pressure) the second just spins in the chuck of my drill press.
I don't have this kind of trouble with 1084 or O1, and those were thicker stock. Any tips on bits, speed, technique?
