I've recently been installing a 1/8" cross pins in into my hidden tang handles where I would drill the hole in the wood block, clamp the blade into the handle, and would use the pre-existing hole in the block as a guide for a stub end mill to cut through the hardened steel tang. This would yield a good results (alignment wise) where the pin would pull the blade into the handle. That catch is that the process would always open up the hole in the handle leading to gaps between the wood and the pin.
To combat this I decided to drill an oversized hole (5/32) in the tang and will use that to mark where I will drill the 1/8" hole in the block to install the pin. I figured that I can avoid accidentally opening up the hole and clearance in the tang can be accounting for by clamping the handle in the glue up and the epoxy would fill the gaps between the pin and the tang. Yielding a strong joint.
Is this a viable option or am I missing something that will come back to bite me later??
