What's the composition of your damascus? Has it been sperodized? have you already heat treated it?more info would be a big help trying to troubleshoot. Also, do you have a drill press? are you centerpunching before drilling? what brand are your bits? (believe me it makes a huge difference, I have had good luck with Sears, Irwin, and the bits I get from industrial supply houses, Harborfreight, Vermont American and some of the other homeowner grade bits are crap) also for annealed steel I have found the plain boring black oxide bits work great as long as they are sharp. For drilling the stuff where I have to drill after heat treating (or O-1 after forging which can have some unpleasant carbides to try to drill through) I usually use diamond bits, but I have just ordered some
bits from Tracy Mickley (Midwest Knifemakers Supply, he's on the forums regularly great source for abrasive belts too) that are designed for drilling hardened steel to test .
-Page
