skinner or utility, The curve before the drop on the spine is a thumb rest.
$110 shipped to your door and will include a simple kydex sheath. You supply clip or Tek-Lok
Full Tang
Handle- 4.15"
Blade- 3.8", edge 3.5" 1/8" stock
Drop point shape, full flat grind spine to edge ground
Handle material-Toxic green G10 chisel textured, chamfered edges , G-Flex epoxy with 1/4" Stainless steel pins and 1/4" stainless lanyard tube.
blade Steel Aldos 1084 Carbon steel mono hardened blade
Blade Finish is belt finish with flats left with heat treat scale
Edge is V- grind on cardboard wheel system
Heat Treat in House, canola quench, 2 2HR temper cycles at 400F
Full Tang
Handle- 4.15"
