I generally like certain kinds of knives to be "drop shutty", although the phrase feels messy.
A big part of this is how I close modern locking folders with slick action. I no more like manually moving them to the closed position than I do slow-rolling them on the open. So I depress the lock and drop them shut. With liner and frame locks, there is a repositioning step. The lock bar is pressed, the knife is moved past the detent, then the finger or thumb is moved away and the blade is dropped home. (A side effect of this method is that detent ramps can cause an annoying hiccup, despite being considered a higher end feature.)
This is pretty natural with flipper tabs of the right geometry because it creates a natural stop point on the finger for that transition. However, not all knives with flipper tabs and slick action have the right geometry for this method and relying on it can cause nicks to the closing digit. Especially using thumb-stud knives with slick action, I've found myself starting the close in a horizontal or outwardly inclined position and gently rotating to a more vertical position for the drop. It might sound complicated but it becomes both fluid and fun with practice.
BTW, "drop shut" as a quality isn't binary and can be discussed as the extent to which a blade falls shut freely and how it feels as it does. Many knives on bearings don't drop with complete freedom and require a tiny bit of momentum. Some need a little shake on the way. There can be a unique feel along the path in closing a particular knife. Some are fast and some are slow. Some knives have an almost hydraulic glide. It can be enjoyable in ways that are hard to describe (almost like ASMR).
The real magic is when a knife can bring joy in doing that while also locking up solidly. On lots of knives, there is a sort of dance in the balance between action and lock-up in the pivot tension. Some knives never reach that balance and leave the choice of unsatisfying action versus a little blade play. Some have a ludicrously narrow window of tension for it, and you've got to dial it in with the blue Loctite. This is actually where I've found benefit in Skiff bearings. They often (not always) help with extending that window.
