- Jan 3, 2007
Greetings,
My question is regarding dry welding billets together without flux. If all surfaces are surface ground flat and then all 4 pieces are TIG welded together tight without using any filler rod, do you have to grind all welded surfaces after the initial WELD fusion process?
I hope to eliminate the grinding part after WELD Fusion when MIG welding the seams.
Regards,
Dennis Paish
Regards,
Dennis Paish
