I use it as a liner in a steel canister to prevent the canister from welding to the contents. Works good for that. If there is a foil thick enough to make folds and not burn out at 2400 degrees you wouldnt need a canister.
My only concern besides holding up at welding heats would be how it holds up under the hammer. I suspect you'll get some tears, especially around the edges of the billet. Maybe wrapping it up a couple of times will help. The foil I use is good up to 2100.
--nathan
I have been getting good welds at 2200 degrees with canisters using stainless tubing, but the only foil I have seen is good to only 2000fh.
I think thats a little low to weld.
Does foil tend to burn out where it is creased?
Tracy at USAknifemaker has the 2100F rated foil.
As for holding up under the hammer, I guess you're likely using a press anyhow to achieve the weld, so never mind on that point.
--nathan
