- Sep 27, 1999
Thanks a lot everyone.
Psy-Ops, I'm not sure I know what you mean in regards to your first point. If I always sharpen it to 20 degrees, what would cause the grind to broaden? And wouldn’t re-sharpening it with eg. a 17 degree angle make the edge to fine to stay sharp for any decent amount of time?
Thanks for the help tho
I wish I had time to draw a picture. The mound between the angle(edge) and the knife will stay at the same thickness. Sal, on his sharpmaker video, speaks and demonstrates the need for this. It has helped me tons when sharpening. You need to remove some of the "mound," for lack of a better word, before you sharpen the edge, or else your edge will get too steep. So you can't always sharpen at the same angle.
If you have a 1/8" thick knife blade, then you only sharpen the angle grind at 20 degrees, but the rest of the blade stays at 1/8" still, all your sharpening will do is shorten the grind. Think of a pencil point, if all you do is sharpen the lead but never remove wood eventually all you would be doing is shortening the lead.
Maybe I am explaining this wrong. Sorry for the confusion.
