Well... I will start again from the very beginning.
I need to "sqweesh" the wootz ingots. They are fairly stiff. The size is about 2...2-1/2" thick and 2-1/2...3" wide. The shape is close to the semisphere.
To complicate the matter the wootz shall not be forged at high heat wich is common for the damascus billet forging. So the steel will be STIFF.
Due to those reasons I chose a 6" cylinder, a 16/4GPM pump and a 5HP/3450rpm motor. The ram will go about 1/2" per sec in high pressure stage. But it is OK.
This set of components should make about 50 ton of force at 3000psi.
If I'll go for the lower RPM I will be "squishing" cold steel(too slow).
If I'll go with the 5" cylinder it will make only 24-25 tons force. That could be not enough to press the 2-1/2 by 3" section of a stiff ingot.
So... so far I understand, that I will need to make a heavily dampened ventilated enclosure for the pump and motor. Potentialy dampen the oil tank. And finish my garage with the fiberglass and drywall.
Probably I will need to insulate garage doors as well.
I guess that all this will easily double the price of the project...
On the other hand I may crank the production about 10 times up.
On the third hand... it will not crank my sales 10 times up...
Ok, another question along the way. Many of you use the regular steel for the business end of the press. And the reason is - any hardened steel tempers and becomes softer. So there is almost no gain in using D2 there.
Did anyone use HSS type of steel? It should me MUCH more rsistant to the tempering and annealing. It should not be hardened though, because of the brittleness. But still it should be harder than A36. Am I right?
