Dumpster Mutt LE at Scrap Yard Store
I've already got my order in, so fill you boots everyone! They are still in stock! :eek:
Compared to most Scrap Yard LE's that is a rare event!
What is spec for it?
Thanks, Vassili.
Here you go...
Dumpster Mutt LE
$129.95
The LE version of the popular Dumpster Mutt features a Full Height Flat Grind, .250 (1/4") thick SR77 Blade that was Satin Finished by hand.
These are a limited production run and will not be offered again in this configuration
Specs at a glance:
Steel: SR-77
Hardness: 58 - 60 Rc
Handle: Resiprene C
Thickness: .250"
Blade Length: 5" with penetrator tip
Overall Length: 9 1/2"
Thanks, Vassili.
Specs at a glance:
Steel: SR-77
Handle: Resiprene C
Thickness: .250"
I never went for the thick CG Dumpster Mutt, but the full flat grind on this one got my attention.
I'm going to give one a shot. It still may not float my boat, but I want to hold one and see.
What I'd really like is a DogFather LE with a similar grind. :thumbup:
+1 bling-bling
Thanks for the heads up. I got one. I know its heresy to many here, but the regular Mutt is too thick for most uses. This is thinner to start with and with the flat grind it will be a better cutter. I'm definitely looking forward to it.
I'm of the same mind in some regards, though similar thickness doesn't seem to bother me on the BATAC LE. It too, however, is full flat.
Can anyone ID that little silver cylinder next to the BATAC LE #1? I'm curious.
