Dust Collector??
I took several approaches to the issue of dust management.
First I did build a separate room for all my more dust producing pursuits involving grinders, sanders and buffers.
This is a nice option if you can do it. I just walled in a portion of my shop and added a door.
At each grinder I use a water trough filled with water and a few drops of dish soap to break the surface tension. This catches most of my dust, and stops almost all sparks. I use plastic or metal dry-wall trays.
I also went the route of dust evacuation to outside using metal ducting, metal gates and a two stage cyclone machine resting on a 50 gallon plastic-lined steel drum, with a few inches of water in the bottom. From this the duct work goes outside behind my shop.
When grinding, I close the well sealed door to the grinding room and open the sliding window in front of the grinder about 3 or 4 inches.
Opening the window draws the air from outside, to the grinder and then through the dust evac system.
This can make the grinding room a little cooler in the winter, but I don’t mind. The room is small and I am usually kind of warm with layers, a lab over coat, billed cap with dust cape, respirator, etc. anyway.
For hand sanding, which I do in the main area of the shop, I set up a box fan with furnace filters on the bench or my stool, a few feet away from where I am working and that draws away almost all that dust. I would like to improve this setup, but it works. I have a large air cleaner in my wood shop mounted to the ceiling, and it does a great job in there, but probably not much of a better a job; just looks nicer.
You can see some slightly older photos here. Old in that they show a much cleaner and less crowded shop…and they show my mock ups for dust shrouds made from wood.
http://www.stoneandsteel.net/dust-management/
I am pretty happy with my set up so far. After running several tests with observers, I just could not get any sparks to make it to the drum, let alone outside even when hogging off steel. But I am still very careful to be aware of the risk.
Be safe,
Brome
This has been enlighting. I've read several threads in the past on this subject, they come up now and then but I guess I was not ready to take action. I am now, I'm just tired of a dust filled shop. Thanks guys!
I found the venting outside to work very well. I used a replaced squirel cage fan from a motor home. Now I'm fighting an inside only thing. Some of these systems are great until you start grinding titanium. The fire thing is a HUGE factor in having something that will work safely. I'm curretly looking at going to a metal container with water in the bottom , a drop pipe near that water level, and the exhaust to the exhaust fan near the top, or possibly a cyclone before the exhaust with a collector container below and even possibly with a bit of a water level. Frank
If you are more concerned with chips and metal swarf then dust, you might wanna look at something Robert Terzuola mentioned (lovingly) in his Tactical Knives book (if you have a good compressor in your shop this works like a charm on chips):
1500 GUN-VAC VACUUM UNIT - GUARDAIR
http://www.travers.com/product.asp?r=s&n=||AttribSelect=Brand='GUARDAIR'&eaprodid=62089-99-020-040
GUARDAIR Gun-Vac Vacuum Unit - Model #: 1400
Applications
Vacuum metal chips, debris, sawdust, pellets, trimmings, crumbs and powders.
Uses standard shop compressed air.
Features
All metal construction.
Static free, no wires or electrical fields.
Contoured comfort grip.
High filtration collection bag.
Tapered nose accepts all standard 1-1/4" vac accessories.
Extended zipper on collection bag for easy debris disposal.
1/4" NPT inlet.
Working pressure: 120 PSI
Includes
9" crevice tool.
Just a thought I hope I'm not breaking the rules here. If I am delete this post.
Syn
Thanks but I believe that's a hand held and requires my control of it as it's being used.With that cloth bag, I believe there might be lots of chances for fires if I was grinding and had it in a position to collect as I did so. Frank
Welcome Ricky,
You may not have looked, but this is a 5 year old discussion.
The dust deputy is regularly recommended.
When pulling up threads, look at the original post date and the date of the last couple of posts.
Thread closed.
