what type of dust mask ?
usually the cheapie painters mask. Lately been using N95’s. I refuse to wear the Darth Vader stuff...
some of you have probably seen this, but I'm a newbie covering my garage in fine sawdust from working on handles. Seems to be the most detailed info on dust collection on the internet: http://www.billpentz.com/woodworking/cyclone/index.php
I’m no expert, but one of the main points he is trying to make is that the stuff you CAN’T see is the really unhealthy dust.Interesting information, but hell does that dude repeat himself!!!
Thats a +1 for venting air outside then
However I wonder how the fine dust relates to metalworking when grinding blades? My old system sucked through a spark bong and vented into the garage with no dust bag in the vacuum when working on metal. I used to see some build up of metal dust on the magnet for the door alarm as it was visible against the white plastic, but nothing that looked ultra fine. And i put that down to the stuff that the vac didnt suck in.
Even in a clean-looking shop it’s easy to have a large amount of harmful microscopic dust that is easily kicked up from surfaces and goes back into the air and your lungs. It’s too small for many of the standard vacuum filters to even pick up.
Got any pics of your setup ? Thank youA clean shaven face and a good fitting respirator goes a long ways.
Look for areas were dust is blown into your face and reroute the dust. My little Kalamzoo loves to throw dust right into my face so made a shroud out of kydex that focused the dust down and away from my face into a well placed shop vac port.
I use a large shop vac attached to a cyclone separator and place the intake hose right behind were my 2x72 goes around the bottom platten wheel. Sparks and meatal go into bucket below the belt and dust is sucked up and out. My shop vac is vented outside and I removed the filter as I clean filter outside anyway and I have not close neighbors. The cyclone traps over 99 percent of the dust, amazing device.
My shop is super small, 12'x6', after 40 knives in the new little shop only a trace of dust is sitting on the harder to reach horizontal surfaces.
