- Jan 27, 2008
Some of y'all will remember my attempts at designing and build a dust evacuation system for my basement shop. The system worked fairly well, but some inherent design problems(of which I was warned by a few folks) cropped up and caused some issues that prompted this re-design. In short, the main issue was water being sucked into the blower which has now rusted the impeller and drive shaft resulting in a loud "grinding" noise when operating. I now have to remove the impeller from the shaft and find/fix whatever has caused the noise. The screw that holds affixes the impeller to the shaft is rusted solid, so that has to be dealt with as well.
I still need to make a more air-tight lid for the top, but so far I'm pretty happy.
However, the new dust collection rig has been fabricated and assembled and it works quite well.... much better than its predecessor. I purchased an old stainless steel restaurant counter top from the junk yard for $ 10.00 and cut it up with my angle grinder, then cleaned up the edges on the grinder. My neighbor then welded it all air/water tight. This design was adapted from one that Ian Hall uses in his shop seen here: http://www.bladeforums.com/forums/s...ow-would-you-do-one?highlight=dust+collection.
I'd appreciate comments and suggestions.
First, the old rig:
Now the new:
with spark curtain removed:
and the inside of the rusted blower:
-Peter
First, the old rig:
Now the new:
-Peter
