WEB2 said:i have a rusty dutch oven, if i turn it upside down over a fire will that clean out the rust so i can use it for food prep? after the rust is out should i grease it and bake it like you would when it is first bought new? thanks in advance.
Codger_64 said:Burning cast iron cookware does not do anything to the rust. The sandpaper (or white silica sand is better, too many oxides in most sandpaper) is what I would use. Then wash it thoroughly, dry it in an oven on low heat, reapply oil with a cotton cloth (not animal oil that goes rancid) and heat it again. As it cools, rub in the oil with a cloth. Don't cook high acid foods in it, clean immediately with hot water (no soap) and then reapply oil after using. Eventually, treated right, the pores in the cast iron will hold oil, and it will be nearly as non-stick as teflon. Plus, believe it or not, it adds a minute amount of iron to you cooked food. Burning was to get out foods and oils that had become rancid.
Codger
You'll have to wait for the movie. If you enjoyed Forrest Gump, then you'll love...Temper said:Codger64, where can I order the contents of your brain on DVD online? Man, you are a fountain of knowledge:thumbup:
My ex got my three dutch ovens eight years ago, but I got our daughter. Sometimes life is sweet!
