The emerson wave feature seems like it would have the advantage, but the speed safe seems fast also.
All you need to reprofile an edge is some kind of edge guide sharpener. I've reprofiled a lot of edges with my lansky sharpener with great results.For duty use with the ease of deployment i can tell you that nothing and i mean NOTHING beats a wave feature. The spring assist is fast, but in order to activate it you need to remove the knife from your pocket completely, then open it. With the emerson ya pull it out and its open. the chisel ground is not that big of a deal imo. if the chisel is something you will not like there are many a people here who could change that for you. search in the knifemaker services offered. good luck in your search, welcome to the forums and be safe out there
The wave feature is really all the emerson has going for it, and this advantage is lost if carried outside the pocket. The ZT 0300 is just stronger, it's titanium framelock vs. thin linerlock. Also, the ZT's S30V should preform better than emersons 154CM. If the wave is something you definitely want you can try to modify the 0300 like a few of us have or send it to FTWCM to cut the wave.
A framelock is strong as hell, but a titanium liner lock is nothing to shy at. Especially in the concept of a tactical knife, and you also have to remember that a typical emerson is going to be $60-70 less than the ZT. ZT and kershaw only run S30v to the same hardness as emerson 154 too, so it's probably not going to perform leaps and bounds over it.The wave feature is really all the emerson has going for it, and this advantage is lost if carried outside the pocket. The ZT 0300 is just stronger, it's titanium framelock vs. thin linerlock. Also, the ZT's S30V should preform better than emersons 154CM. If the wave is something you definitely want you can try to modify the 0300 like a few of us have or send it to FTWCM to cut the wave.
The 0200 can be waved with zero modification and proper technique. Just pull downward and/or away from the edge of the pocket and the thumb ramp/thumb studs will catch on the pocket edge, thereby opening the blade very quickly. I think the 0200 is the best way to go and it also happens to save about $60 compared to the other two options.The operation is very smooth with the thumbstuds or flipper, so it shouldn't be a problem to get it out fast. Yes, the wave will open your knife faster out of the pocket, but it will also tear up your pants, so you won't want to do that a lot.
I'll wave mod pretty much anything possible.
could you post some pics of your zt that you have put a wave on?
