1996 VFR16 Pit Bike
Feels and rides like a brand new bike. Everything is tight with no play anywhere, no parts making funny noises, no loose chain or loose bearings etc. Always stored indoors. Very solid bike with minimal rust in the usual spots. Excellent condition for a 25 year old vintage bike.
The bars, stem, layback seat post and custom gearing makes this bike rideable by an adult. I'm 5'8 and I've been riding these 16 inch pit bikes to run errands around town for several years.
The gearing on this bike is the same gear ratio used by BMX racers on 20 inch bikes. The ideal BMX gear ratio is 55 which is achieved using a 44t chainring with 16t sprocket on 20 inch wheels.
On a 20 inch BMX The calculation is (44 / 16) x 20 = 55
This bike has a 33t chainring with 9t sprocket on 15 (the actual diameter of a 16 inch wheel) inch wheels.
Calculation is (33 / 9) x 15 = 55
The gear ratio is what makes this bike fun and comfortable to cruise around on.
1996 Dyno VFR 16 Frame
/w stock 114mm one piece cranks
New OEM Bottom Bracket bearings
New OEM headset bearings
Black Ops Translucent Pedals
Dyno Stamped Handlebars Chrome from larger model VFR
Dyno Stamped Inverted Stem from larger model VFR
New ODI Softies Pro Grips
New 16” S&M unbranded rims 20H
New 9T freewheel rear cog
New 14mm to 3/8” Rear Axle conversion (so front and rear are both matching 3/8" axles)
New 33T GT Front Sprocket
KMC Gold Chain
New 16 x 2.25" Kenda Kontact Tires Grey with Black sidewall
Layback seat post
GT Aluminum Seat Clamp with quick release
New Generic padded seat
New Odyssey 1999 Brakes – caliper, lever, cable
New Odyssey Slim-By-Four Clear Brake Pads
Box Components Chain Tensioners
$1100 Shipped using either UPS Ground or Shipbikes.com
KMC Gold Chain
Layback seat post
