Eagletac P100a2 2AA Flashlight With Sheath (GONE).......
jeepin
Feedback: +397 / =0 / -0
I have a used Eagletac P100a2 flashlight which uses 2 double AA batteries. Its in great shape and comes with the optional eagletac nylon sheath which was purchased seperately.
I would really like to trade it for an unused black esee izula, but I will consider all offers. Neck knives, small fixed blades, gadgets, gear, automotive tools, gift certificates, etc.
Pm or email me at mashguy4077@yahoo.com if interested.
Here is some info about it.
The EagleTac P100A2 outputs up to a blazing 325 Lumen (236 ANSI Lumen) output, and up to 8 hours of runtime using two AA batteries. EagleTac packs a powerful and technology advanced tactical light into a small package, and offers dual brightness beam by turning the bezel.
CREE XP-G Cool White S2 LED features outstanding low thermal resistance and low forward voltage for extreme power-efficient operation. Its low-profile emitter position works flawlessly with EagleTac optical reflector for great output and pleasing beam.
or
CREE XP-G Neutral White R4 LED P100A2 is available in vision-friendly neutral white for better color rendition and greater visibility in fog, rain and snow.
Turbo Output offers up to 325 Lumen output. Select Turbo output beam by tighten the flashlight head. Turbo output beam is current regulated and maintains 1.5 hours of constant brightness with two Sanyo Eneloop batteries.
8 Hours of Runtime General model offers up to 55 Lumen output. Activate general model by twisting the flashlight head clockwise from the Turbo mode position. General output beam is current regulated and maintains its constant brightness for 8 hours with two Sanyo Eneloop batteries
Syntax I Window P100A2 features shock-mounted Syntax I lens for maximum light transmission and superior shock-proof ability. Syntax I windows allows up to 97% light transmission with its optical-grade anti-reflection coating. Harden treatment is also performed on the Syntax I windows to enhance durability
Superior Ergonomics The P100A2 body features pocket-friendly knurling for superior grip and handling. The protruded tail-cap switch allows easy access and easy momentary click.
Type III Anodization Mil-Spec Harden Type III anodization treatment is applied on the P100A2 aircraft grade aluminum to enhance surface protection. EagleTac type III anodization coating is on average 200 to 300 times stronger than the regular Type II treatment. (MIL-STD-810F)
IPX-8 standard P100A2 is rated at IPX-8 waterproof standard for all weather conditions. P100A2 is fully dunk-able at two feet depth of water for more than ten hours.
Max Output 55 / 325 Lumen
Runtime 8 / 1.7 Hours
Operations Select brightness by turning the bezel
LED Cree XP-G S2 3W LED
Material Mil-Spec Harden Type III anodization treatment is applied to the aircraft grade aluminum
Length 6.1 inches (15.5 cm)
Diameter
Head Diameter: 1" (2.5 cm)
Body Diameter: 0.8" (2.0 cm)
Weight 2.8 ounces (80 grams)
Battery Two 1.5V AA batteries (also compatible with 1.2v NiMH/NiCD rechargeables, and Energizer e2 Lithium 1.7v Cells)
NOTE: 3.6v-4.2v Li-Ion Rechargeable Cells should NOT be used and will void Manufacturers Warranty!
LED Color Cool White or Neutral White
