- May 16, 2014
My Xm-18 is early lockup. ~ 10-15%. Is this normal?
And what is pros and cos of early lockup?
Thanks!
[/URL][/IMG]
Thanks!
I'm definitely not an expert on lockup, but I'll gladly give my opinion and thoughts on this.
I've never had a Hinderer, so I cannot tell you if it's normal or not.
As far as the pros and cons of early lockup..
If the lock-bar/liner is susceptible to fairly easy wear, early lockup would give you a lock that lasts a longer amount of time before becoming 100% and unreliable.
Unfortunately, early lock-up also means that you'll have a weaker lock, given that it's only being locked open with a tiny bit of contact, and the bar could quite easily move off of the blade.
As far as well-made titanium frame-locks go, having lockup 40-85% seems to be pretty common, brand new, and they tend to stay at around the same percentage over years of normal use.
cons - it might fold up on you under high torque, maybe. Probably not. I really wouldn't worry about it if the knife feels solid when locked open.
pros - score! It's much better to have an early lockup than a late one. Early lockup usually means the knife is solid, and quality built. It also means the lock can account for lots of wear. I think you got one hell of a knife there pal.
I suppose that I didn't word my thoughts all too well. This is what I meant.
Heheh. No kidding! I can't imagine what situation you would be in that would require you to use the knife in a way that would do that.I figured! I just didn't want the guy thinking his lock was faulty just because it's early. It shouldn't fold up unless he puts a HELL of a lot of force on it in the wrong direction.
Great point to add!Once you use/break in the knife it will settle in a little more.
Folks seem to think its a good thing these days.
Personally it's not acceptable.
I just sent a bada$$ custom I received today right back to the maker and tore him up on the phone for letting it leave his shop.
Mastering engagement on a frame lock is something few have mastered.
Well said! IMO there's no good reason for a lockup that early and it would not be acceptable. I've had user knives for years that started around 50% where the lock never even came close to 100% long before the days of steel inserts and carbidizing lock faces. The fear of lock bars wearing to 100% is hugely overblown. If you have a 50% lockup that goes to 100% even over a few years of use there was something wrong to start with on the knife lock.
It's probably like 1911s with slides so tight they barely function that are so popular now ....customers wanted it so makers responded even though slide tightness has almost nothing to do with accuracy but hurts reliability significantly in adverse conditions.
