There's nothing wrong with oil quenching an air hardening steel. Why would you be crucified?From your list, I'd go with O-1. (Don't even think about oil quenching an air hardening steel, unless you like being crucified on-line.)
- Mitch
Why??? Now THAT'S the $ 64,000.00 question!There's nothing wrong with oil quenching an air hardening steel. Why would you be crucified?
Originally Posted by Troop
From your list, I'd go with O-1. (Don't even think about oil quenching an air hardening steel, unless you like being crucified on-line. )
- Mitch
- Mitch
I may sound like a heretic, but in my experience, a Nicholson file is almost fool proof to come through a simple heat treat with outstanding performance. I worked with them off and on, for over ten years, on a regular basis. They hold not a good edge, but a great edge, and if they are softened on the spine, they make excellent knives. Very rugged. I realize that I will catch hell for such a simple treat, but, normalize if forged, heat to red-orange in dim light. Quench in ATF. Sand until bright clean. Carefully run a propane torch over it until you get a brown color at the edge, three times, Then put it in a pan of water, about 3/8" deep, edge down, and heat the spine until it goes through all the colors then becomes neutral. After this, carefully heat the point area to a purple peacock color, CAREFULLY and SLOWLY!!! At this point you will have a more than adequate heat treat for that steel, and it will hold an edge very well. From this you can move on to even better steels, but this will give you a very usable knife, relatively easily done. I apologize to all for such a simple approach,. but I guarantee it works. With Nicholson file steel, at any rate. I am sure it ain't the best, but it is impressive for the sake of simplicity, and that's what this guy is looking for.
I already made a knife from a nicholson file. I wanted to try blade steel but the heat treating is all too confusing for now so I guess Ill order some S30V and send it in to be proffessionaly heat treated. Its not that expensive and that way Ill get more stock removal practice before I start the H.T and the S30V
What exactly is a fantastic oil quench? I was planning on motor oil but I never knew one was better than another? Is motor oil any good? My flame will be simple, either an extremely hot fire or a propane torch.
Kessik,
Welcome to Shop Talk. Fill out our profile so we know a bit about you.
When searching for info, look at the original date of a thread so as not to necropost an old dead thread.
Just a FYI, but your HT method for O-1 is not sufficient. O-1 requires a 5-10 minute soak at 1475-1500F before the quench. Your temper of 450F is OK for a rough use blade, but 400-425 would give you more edge life. The stickys has some good HT threads. Also, a search will get lots of O-1 and other steel HT info to read.
Your forge sounds inventive. Shows what can be done with little investment if needed. Maybe not perfect, but workable. Out of curiosity, what kind of coal are you burning?
I observed a temporary sword forge very much like your setup. It was a pipe with a bunch of holes in it set in the bottom of a long trench in the ground. The sides were packed with a dirt/sand/ash adobe to make the fire pot. An old hair dryer provided the air supply ( the type with a hose and a plastic hood for the head). Charcoal was burned in it to do the yaki-ire for the sword.
