So 2” is fine? I was thinking 2.5”.I prefer one on the taller side to allow knuckle clearance for my large hands. Typically around 48-52mm total blade height for me.
In my opinion, yes. Many make Nakiri short than that, some make taller, but I think it’s a good height. Much more and it starts to approach a Chinese cleaver. I don’t like knives much taller than 2” because my hand ends up too high above the board. It feels more unwieldy to me.So 2” is fine? I was thinking 25”.
What stock thickness do you like to start with for your paring knives?
Ive gone 2 1/2-2 3/4” but I ask the client first if he’s used one that he/she has liked and how tall it was? You can also cruise the Japanese knife web sites and Get some dimensions ..How tall do you guys make a Nakiri? A friend just asked me to make him one. I would never take a new model as a sale, but for a friend for feedback, I’m open. I was going to ask @HSC, but his inbox is full. Tia.
Butch - not sure what you are referring to by the 2” mark? Are you referring to 2”-itis?the biggest thing you wil have to look out for is te 2" mark you can mostly hide is on hunters and chopers but never on a kitchen knife or razor
I don’t , but I’ve found leaving a heavy Scotchbrite finish does the same thing. Another reason I don’t care for a mirror polish on a culinary knife.I have noticed that a lot of Nikiri have a hammered or a Granton edge so food does not stick a bad. Do you all do a granton edge or leave it smooth?
the one commercial example I have has something like a 1.25" - 1.5" bevel. I personally would want it to be shallower - and so would take it up higher (as I have done on similar knives).How far up the blade on a Nakiri do you bring the grind?
FWIW, what I do is start the bevel ... then walk it up and up and up ... until I just can not hold a clean line - then I go further, until you pretty clearly start seeing scratch marks a ways above the shinogi. then I use that bevel angle to refine the edge down to 0.005-0.008 (I still can not go thinner than that). then, as I go to finer grits and ultimately to scotch bright, I blend the bevel and the flat at the shinogi. If you want a really clean straight shinogi ... the tradeoff will be in a steeper bevel, and a less cleanly cutting blade.....
I’m not sure if I am being clear: if you take bevel wide enough, and hence the angle between the flat and the bevel small enough, just the variation in the height of the grit on the belt starts producing scratches above the shinogi. I go to that point intentionally ...as when I then blend through that transition with finer grits, the transition is, while not invisible, not at all obvious (on a really wide blade a ffg is just not that practical .. plus you start having issues with a plunge at the tang...Tru using a flat 1/4” piece of steel with a magnet to hold your blade when grinding. I used to do this until I got better muscle memory with thin stock to grind evenly. A crisp shinogi is still my Achilles heel after 450 blades.
